Toggle navigation
User Info
On-Site Experiments
Mail-In Program
Remote Operation
Science
Biological Science
Materials Science
Techniques
SAXS/WAXS
GISAXS & GIWAXS
Microfocus SAXS/WAXS
Solution SAXS/WAXS
Equipment
Beamline Setup
Sample Environments
Lab Equipment
Software
Controls & Acquisition
Data Processing & Visualization
Data Analysis Software
Resources
Staff Only
Sample Environment Details
0.5ml Tubes
Mail-In
Details
For Bio or other aqueous samples (non-capillary).
Samples should be well labeled either on the cap or the side, volume >=140 uL, and ready to go after centrifugation.
If labeling on the tube side/body, use permanent marker only (no tapes), otherwise the tubes will be too fat to fit in the sample holder.
Tubes are run using a home-made autosampler.
Support:
Autosampler Setup
Notes:
Provide sufficient buffer solution, both in 0.5ml tubes (for measurements) and large tube (for flow cell washing).
Recommended 0.5ml tube:
VWR Disposable Microcentrifuge Tubes
Experiment
Beamline staff will unpack your samples the morning of your experiment and stage them inside the station.
Remote operation
requires additional instructions and orientation.
