We recommend sealing with Devcon 5 Minute or 2 Ton Epoxy. If you have not used these before, you may need some practice to get a feel for the mixing and hardening times.
Works for glass/quartz capillaries and kapton capillaries; quartz capillary is preferred because of its high mechanical strength. Commercial Sources: Hampton | Charles Supper
